OK I just came in........arrgg.....this is getting fun.
All the outside fiddling hasn't helped. It started to backfire through the carb every so often (clue Norman?) so I decided to attack the beast.
First of all I took the carb off and took it apart. Pretty simple really (yes Norman the O-ring was still there). The main jet appeared clear. I didn't mess with this:
http://motorbicycling.com/attachment...arbpict014.jpg
Should I try messing with the float???
Put the carb back together. Then I took the manifold off. Found a big oops there....I didn't realize how lousy the gasket matched the engine. A big portion of the ill fitting gasket was being pulled into the engine. So I carefully cut the gasket to fit.
I put a new O-ring in and buttoned it all up with a little sealant.
It fired right up, sounding really good, nice midrange power....but go for full throttle and BOOOOOOOOOOOOOOOGGGGGGGGGGGGGGGGGGGGGGG......
Dern.
So far I didn't mess with the needle.
Originally Posted by deacon It is possible you got all there is out of it. |
Something is fundamentally wrong.
Originally Posted by Bikeguy Joe Try one notch lower on the needle clip and see what changes. |
I just did and it made it worse. That should make it richer. Indeed it did. So next I will try the top notch, I guess.
