Re: Zbox Got 2 of my Z80 engines from ZBox... I burned my first one, because the intake gasket got screwed and was not aware of it. My 2nd seems to be still running good, but had a small hole near the exhaust from cast bubbles. I just cold weld it. I cut out my own intake gasket from gasket paper and made sure it covered all area of contact and make a good seal.
You can use the shifter kit from SBP to drive your bicycle gears, tuned pipes from Andy and some other guys. There are lots of products you can find here. Also, a clutch upgrade kit.
__________________ The Noah's Ark was built by amateurs, the Titanic was built by professionals. I build my Motorized Bicycle. Caution: This hobby is habit forming.
Reason: add info
