  #9 (permalink)
Old 10-28-2008, 04:51 PM
Cr9ck Cr9ck is offline
Default Re: How do you detect air leaks?
Yeah I figured it out. it only runs if i really choke it. I sprayed wd-40 around where the carb connects to the intake manifold and it revved up the first time. I tried it again and this time when I hit it with wd40 it revved down each time I did until it cut out... The intake manifod itself seems fine and the part where the carb connects to it is tight.
I have also detected that around the primer pin near the screw gas is leaking. Perhaps it is leaking out the side of the carb. I tightened the screw but I think it is still leaking.
Any help would be greatly appreciated.
Thanks
