Old 03-08-2008, 08:59 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Deacon's bike build
Sounds good to me takes the heat off me for a while.
Deacon your doing fine. I use a combination of regular grease with 90wt gear oil the gear oil is a syn. made by Royal Purple I think they also make a grease but this combo works to make it roll the best I've seen. Pablo might have a product as wel cause he sells amsoil which is also a very good product line. The down side of syn. oils is the price BUT it worth the cost I eally mean that I've seen tests that prove the syn. work when nothing else will.
I don't use syn oils in the airplane the only reason why is syn. oils and leaded gasoline will from a sludge that will ruin an engine and I've yet to be able to land on a cloud and pop the hood to take a look see.
Rufus says high to all of you out there.
NORMAN
norms-iron-works.tripod.com
