Old 10-13-2008, 07:39 PM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
Default Re: List of the best top quality long lasting rugged engines
The short version is this.
Anything built by a recognised manufacturer - ie honda, tanaka, robin and so on will be reliable and more or less fit or forget - inasmuch as your engine is not likely to give you problems although the drive system might.
Industrial two strokes such as the Tanaka benefit from a tuned pipe and adjustable carburettor as do the CIF engines but the manufacturer engines are more likely to be reliable and long lasting than the CIF 2-strokes (Chinese In Frame). There is also the advantage that the manufacturer engines are low emissions and high performance.. for example my 32cc Tanaka with pipe will top out at 35mph on flat roads as compared with the CIF's 50/60/'80' for roughly the same performance but using more fuel and at a higher oil mixture.
To be honest I would go with a two stroke manufacturer engine on either a Golden Eagle or a Staton kit. Flexible, reliable and eminently tunable - 2 strokes are simply the right tool for the job. GE & Staton are the best of the mounts - belt and chain respectively, although the Dax Titan is also good but fairly noticable.
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
