Originally Posted by Bikeguy Joe I'll add the obvious....look for one with or without rear suspension that you can still fit the engine within the frame. Also, if you plan on using it for off road, you may want to look for a beefy frame (compare) and use one of the 46 or 48 tooth sprockets for more low end grunt.
These engines will haul a lot of weight so don't be overly concerned with the total weight of the bike/rider. |
Thanks for the reply.
Yes I am tall and shall I say "average weight for my 6'6 frame. I am 250 pounds, so I like and look "normal" on a beefy mountain bike. I know that most of the beefy frames are rather large and would wonder if the engine would be able to fit and work with a larger frame. I spoke with a dealer not to long ago and he told me that some bike engines have a hard time bolting to larger diameter frames. I was unaware that a 46-48 tooth sprocket could give more low end. With my weight I would need it. Thanks for your post!
