Originally Posted by misteright1_99 The float is inside the carby bowl, you take the two screws out and remove the bowl and you will see the plastic float, the arms that it pushes on and the pin the stops the fuel flow when full..... Carburetor pictures how to install and rebuild
Posts number 8 and 9 I believe....... |
Thanks for the info, I just finished doing it and so far so good... thanks!
