Re: I would like to know Would using JB-weld and a plate of metal get you close to where you want to be? Use the quick set JB to glue on a mount for your thing. You can use masking tape to build a dam to put the JB in to build up the area then grind it to shape with a dremel or file/sandpaper etc. Just some ideas for you .
