Old 09-27-2008, 09:33 PM
stewood stewood is offline
Motorized Bicycle Apprentice
Default Re: Problem with the Clutch
Originally Posted by misteright1_99 View Post
In front of the rod is a ball bearing. Get a magnet to get it out. Shoot some grease in there, insert the ball, more grease then the rod, then more grease on the clutch arm, put it back together and retry. It is also a good idea to unscrew the clutch cable adjustment anchor and pump some grease in there. I use a grease hose with a needle to get it there.
That did it. Thank you very much!
