Re: Motorized Bike Lurching a Bit Quote:
Originally Posted by angus Deacon - It appears that the combination of running at (too) low rpms and babying the motor during break-in caused the lurching. The little sucker loves the throttle and has started to purr a wee bit as I have given it more and as it breaks in. Definitely give it the throttle! Don't baby it past the first 5 minutes.
I'm impressed with the little engine. It runs smoothly (so far) and fairly quietly. It sounds like I'm riding my chainsaw!  I'm running stock plug wire and plug and built a wiring harness for it; therefore, shorting / grounding potential is minimized (hopefully). A good plug/wire/cap will do you a world of good...try it, you'll like it.
The gears make the characteristic whine. I'll try a wee bit of grease as I've seen in some posts. The chain is stretching; gonna have to take out a link soon. Lithium, or white grease is best, don't get crazy with it! | .................................................. .................................................. ....
