Originally Posted by machiasmort Biker Mike
Before you rework the whole thing!!!! I like the mount!!! Try walking arround a good hardware store or two...
Look at Rat trap springs and other springs of similar nature! I've been doing some thinking myself. I want to see this thing work for you safely! You seem like the kind of guy who will give feed back... And are also 1 step ahead of me. I thought of one of those springs that hold screen doors shut. The kind that are not long(snake like) but C shaped that rock stationary and snap (hold tension) on the door when closed.
Are you familiar with what I'm describing or should I send a pic? The spring is small like the chain tensioner but snappier. It has two rubber rollers (one on each end).
Please be carefull. Chain derailment is no joke! |
Not sure what it looks like. I think I found what I need thou, just need to find a place that carries it. I was looking at my cut off saw the other day and it has a spring that works in the opposite direction than the one I used. I think it will work better. I haven't given up in total defeat just yet. Just postponing it a bit to catch up on other honey do's.
I'll re-post when I come up with one that works a little better. Thanks for the words of encouragement. it helps to keep you going thru the head banging portion of brain storming.
