Old 09-23-2008, 08:01 PM
Creative Engineering's Avatar
Default Re: New product announcement
jasonh,
The factory actuator assembly is riddled with geometric problems. For clarity I refer to the actuator as an assembly consisting of the housing, cam, and link arm. The entire assembly is offered from Creative Engineering, with hardware and an allen wrench.
The housing:
First, the housing is a die casting. Die castings are fine for items like the magneto cover, the clutch cover etc. These items are simply covers and therefore are not required to offer any sort of mechanical support.
The clutch actuator housing on the other hand holds the cam which pushes to through rod to open the clutch.
The factory die cast housing is not stout enough, so it deflects about .015" when the clutch lever is pulled.
Second design flaw: There is .030" clearance between the hole in the housing and the cam rod. In other words the shaft is sloppy in the hole. This drastically increases the friction for any given clock position.
Lastly: The relationship of the cam centerline to the pin centerline was way off from the factory.
The fix:
A housing machined from 6061-T6 aircraft grade aluminum toleranced according to standard engineering practice. Dead-on cam centerline, .001 clearance between the cam and housing, enough material thickness the eliminate deflection.
The cam:
The original cam geometry is nothing more than half the diameter milled away. This works fine when used in conjuction with a light duty application such as triggering a microswitch.
The fix:
Our cam has an eccentric milled into it that allows the through rod to push open the clutch gradually with little effort just like any small motorcycle. The milled flat in the factory unit makes clutch operation an all or nothing function. Due to the gear ratio, engine operating RPM, and wheel diameter: an all or nothing clutch reduces the ease of manueverability. I can do tight figure 8's in the shop parking lot with zero effort.
The Link Arm:
From the factory the cam has been hardened and straight knurled at the top; then the link, (soft steel), is pressed onto the cam. For many application this works fine...I've used it myself...but not here!
The fix:
Our link arm secures to the shaft via a taper, the taper is infinitely variable for ease of adjustment, and once tightened "CAN NOT" slip, strip, or otherwise fail. In addition we made the link arm 1/4" longer for leverage.
In summary, it wasn't just any one thing that needed to be corrected. The entire clutch actuator assembly is poorly designed, using the wrong materials, and the wrong clearances.
Pablo
Thank you,
Yes it comes with a new housing...it was necessary in order to make the clutch work the way it now does.
Jim
BikeParts
