Re: take a tip...leave a tip You can also make a head gasket out of aluminum sheet metal available from tractor supply for $6 (same cost as 1 replacement from ebay). The sheet is large enough to make like 8 gaskets and is the same material and thickness as the original. This way you retain your piston to head clearance from the factory and can make many more gaskets in the future from the same sheet... |
