Alcohol fuel and bicycle engines Guys
You all want more power speed etc. Alcohol has been talked about in the past on other forums. I'll tell you all a little that I know about it. It is lower in BTU but you can cram more in the cylinder for each power stroke that is one of the reasons for a power boost. You and run very high compression as it will not detonate like gasoline will and more but i don't want to go into detail.
Ok now the down side your mileage will go to heck. The stuff will eat fuel lines and seals. It will also eat the aluminum. It likes water and will draw water out of the air and rust up the internal bearing or any steel parts. You need to use a special oil in the premix oil as your regular oil will bead up and not mix. Caster oil will mix the last bottle I bought was $8.00 for a pint. Some synthetics will mix but all cost more than the oil for gas. Some synthetics cost about $20.00 a gallon or more. You all getting the urge not to use alcohol yet? Its recommended to drain the alcohol out of your engine after every use and flushing it with gasoline to keep the alcohol from eating up the engine and to stop the rusting of steel parts that will follow. That means even the fuel tank. Last time I bought alcohol fuel it was over $3.50 a gallon and that was 7 years ago.
So you still want to use it?
If it catches fire in the day time you will only know you are on fire cause of the extreme heat you will suddenly feel that can't bee good. You will not see the flame, at night it burns a pretty blue.
Nitro you don't want to mess with. That will cause you more trouble than its worth instant engine melt downs if used wrong or nasty explosions.Its not cheap either. Fumes can contain nitric acid and that will eat lungs and skin. I don't know if you can buy the stuff pure any more in bulk after 911 unless you have a nitro burning fueler or a licence for the stuff . I haven't tried. You might even get on one of those watch lists if you do buy some.
Did I talk any of you out of it yet? I hope so. But if you just got to try alcohol I warned you. I still have a alcohol fueled go kart and would like to sell it PM me if your interested. I could modify a stock carb to run on alcohol by drilling the main jet and testing but I'm not interested in doing that right now. When alcohol and the Castor gets cheaper than gasoline and its oil I'll go alcohol but not until I'm sure of it. Something for you all to think about. If you want to smell and hear alcohol and nitro go to the NHRA drags you will be blown away and you won't trash your engine.
Norman
