Hot Whizzer Parts Hi Everyone,
I specialize in Performance parts for the new edition Whizzers [1999 to present]. I still hold most of the speed records with my Whizzer motors, including 68 MPH on a dyno, and two classes at the Dirt Drags [stock appearing & modified]in 2007. I do this as a hobby, not a business, therefore I can offer parts at a lower price [very little overhead]. I just received a long awaited order of hi-lift camshafts [20] and will weld the gear in place and degree each unit. I will include the actual degree wheel information sheet with each camshaft showing the open & close of the valves, the duration, and the lift of each camshaft. Because of the lift, mushroom lifters must be used to avoid "cutting" the camshaft lobe, therefore I will offer this as a kit. The kit will contain the camshaft, special mushroom lifters, and a #2217 tappet cover gasket. The average price of hi-lift camshafts is $150.00, the mushroom lifters retail from $60.00 to $105.00, and the gasket is $1.80. I will offer the entire kit for $150.00 [plus shipping]. If you have a NE or SE motor then this camshaft isn't for you because those motors already have a hi-lift camshaft and the difference isn't worth the money, but if you don't have mushroom lifters, you should install a set for increased camshaft durability, and a slight improvement in performance [$50.00 set]. For some reason, and I don't know why, this camshaft lowers the operating tempature of the earlier WC-1 motor while adding a lot of extra power. For anyone that has upgraded the WC-1 motor using the NE cylinder kit, this camshaft kit is the "missing link"
to make your motor a real "fire breather". I only have a small quanity, and waited over a year to obtain these, so if interested, contact me soon.
Whizzer OuterBanks,
Quenton |
