Re: removing and adding chain links on motorized bicycle chain key to it is only press enough for pin to drop thru cap it will give and fell a click when you are free then do the other pin and remove the cap and slide out the other part. when you get the tool practice a few times with some of your extra links you have. once you get the hang of it you can replace or ad links in a second. |
