Old 09-13-2008, 06:34 PM
eDJ's Avatar
eDJ eDJ is offline
Default Re: Notched Piston Skirt
You may want to read this page and understand the message presented. Hirth has been around awhile and are definately doing something right.
Hirth Text.html
Probably the simplest, least expensive mod one can make on a 2 cycle is the addition of an expansion chamber. It's a straight up bolt on that will provide impressive results no matter how sloppy the ports are in a production cylinder.
Unless it's time to tear down and re ring concider a simple bolt on for now.
In expansion chamber designs there is what's called a "torque tube". Among the truncated cones of the chamber there will be a parallel band somewhere about the middle. This chamber will increase torque all thru the rpm spectrum and provide the feeling of added power.
I've seen guys go thru trick pistons and fancy porting in their cylinders only to
wind up with less than what they had to start with, at great cost of time and money when they could have been riding and enjoying.
Many owners will take their piston and insert it into the cylinder using a scribe
and the top edge of the piston as a straight edge to mark the ports tops and bottom edges so they are all equal. Thus each will flow about the same opening and closing all at the same time. I've seen pistons with holes in the skirts to allow transfer. There many things that can be done but bear in mind that on the evolutionary chain these little "China Wonders" are primitave at best.......cheap.....and just fun to bolt on and go play with. Unless engine building is more fun than riding then you can make your choice and I'll post what I can to support it.
