Old 09-13-2008, 08:51 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: 2 stroke clutch not engaging
Remove the small screw that holds it in place. Then, pull in the lever and lock it.
If your clutch is dragging, that's a waste of time. You will want to remove the cable end, adjust the cable adjustment at the lever and the engine to the middle of their respective adjustments, then have a helper push the arm until good resistance is felt. Re-install the cable end.
That will usually do it.
