Old 02-29-2008, 10:05 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: things that need to be invented
Deacon
YOU should LISTEN to your wife go BUY one NOW before she changes her mind. I think the wire feed would be the way to go as you can weld very thin metal with it. Good Luck my friend. Its not that hard to learn Bob says if you can squeeze tooth paste out of a tube, you can weld with a wire feed. I can, but I get the paste all over the place.
Norman
norms-iron-works.tripod.com
