Re: HT Main Jet Size? I use a propane torch and electrical solder, I also use a resin type flux when soldering. Don't need much heat use needle nose pliers to hold jet in the fire then tough the solder to the hole and it wil flow into the hole very little solder is needed, to drill the hole I use a pin vice to with micro drill bits to drill my main jets by hand with the main jet mounted in a vice. works for me with no problems. |
