Re: total tear down pushed the shaft back into the case from the clutch side the bearing will sit recessed in the case,the bearing will bottom out on a machined lip inside the case.
looking at the side where the sprocket will go after the bearing is pressed in place the bearing will also fit in the case recessed and will bottom out on a machined lip and you can't drive it in any farther
the bearing is being put on the sprocket side of the shaft
