Re: total tear down this is the shaft that the cluth rides on and the front drive sprocket all layed out in the way it goes together I'm pointing out the clutch spring this is what puts pressure on the plates and not the little spring out between the plates. under the clutch spring in the picture is the shaft that goes inside of the main cross shaft. it is the shaft that the flower nut attaches to and pushes the pressre plate off the clutch pads pretty cool how it works. I reassembled this and greased the inner shaft and the bearing.
