Re: total tear down it bolts together with 1/4-20 bolts. rough looking
this is how it would be used to ream out the bushing if I had pressed in a new bushing lacking a ream you might be able to hone it to size with a brake hone. If you get a bushing from a dealer after it is pressed in it might not need to be reamed.
