Old 02-27-2008, 09:32 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: total tear down
Here is the wrist pin
Take a look here is the bushing in the rod see how its not centered. That is the reason I'm leaving it alone for now. That few thousands make the rod just a tiny bit longer and can change things. With the cylinder on and a 0.030 base gasket my piston top comes out of the cylinder and the head gasket keeps it from hitting the head. On Briggs flathead alcohol engines we decked the block so the piston would pop up out of the cylinder and the rules use to state no more than .005 pop up if I remember right. But that is on a 4 stroke.
bicycle-engine-total-tear-down-totalteardown017.jpg  bicycle-engine-total-tear-down-totalteardown018.jpg
norms-iron-works.tripod.com
