Old 02-27-2008, 09:17 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: total tear down
1. before you remove the piston mark it so you know which way is forwards if you put it in backwards it might hang a ring up on a port and destroy the thing. I later marked it with a scribed arrow to the front.
2. My wood piston support and pointing to the wrist pinkeeper
3. getting ahold of the keeper I remove it with sort of a twisting and gentle pull I remove only one keeper. I would replace it with a new one if I had one as you are not supposed to reuse them but being careful not to distort it you can get by notice the rag that is in case the keeper jumps into the crankcase.
4.There the little booger is sort of like pulling teeth.
bicycle-engine-total-tear-down-totalteardown016.jpg  bicycle-engine-total-tear-down-totalteardown013.jpg  bicycle-engine-total-tear-down-totalteardown014.jpg  bicycle-engine-total-tear-down-totalteardown015.jpg
norms-iron-works.tripod.com
