  #54 (permalink)
Old 09-08-2008, 04:10 PM
lennyharp's Avatar
lennyharp lennyharp is offline
Default Re: bicycle engine clutch.
I did the sanding trick and the clean the pads trick and took needle nose pliers to the star nut and worked it in as far as I could while pulling the clutch lever. All that kept the clutch working for a few hundred miles till the motor mount bolt broke off at the block.
The set screw does go between the tabs of the nut and it can only back out so far before it hits the screw.
LennyHarp of Lenny's Bikes & Things
http://lennyharp.net
