  #53 (permalink)
Old 09-08-2008, 01:33 PM
jasonh's Avatar
jasonh jasonh is online now
Default Re: bicycle engine clutch.
So here's one...
My set screw was also gouging into the cover. I tried tightening the star nut, but then I just couldn't disengage the clutch. For now I have a thick cardboard gasket on there to prevent more scoring, but that's lead me to lose all but 2 of the cover plate screws
So here's a list of things that are funky with my clutch:
set screw grinds on cover plate.
the "plate" that the star nut holds on has some play in it both with the clutch engaged and disengaged. It can wiggle and make noise, and will rattle at higher rpms.
The set screw doesn't really set the star nut. If I "set" on one of the tabs of the nut, it lets the nut slip. If I set between the tabs, the nut has that little bit of room to rotate before hitting the screw.
I'm thinking what I need to do is turn the flower nut in all the way, then screw in the two adjusters on the cable, and reset the little brass thingie on the end of the cable. Then use the screw adjusters and try to get the clutch to be able to engage/disengage. Not sure that'll work, but it's worth a shot.
Any suggestions to keep that plate from rattling? Drives me nuts at higher rpms.
