Old 09-07-2008, 09:26 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Clutch Seized??? Help!!!
You are saying that the clutch doesn't disengage?
Adjust the adjustments on the cable halfway in on both ends, loosen the cable end piece, push the lever over tight, then tighten the cable end down tight while holding it against the lever arm.
Adjust the cable end adjustments until there is 1/16"-1/8" of freeplay in the lever end.
