Re: Anyone in Winnipeg MB want to make a few bucks there are two ways a sprocket can be "out"...on it's axis (forward and backward) and laterally (side to side).
I've noticed more than a few sprockets are actually warped...meaning: if you took it off and layed it on a perfectly flat surface, you'll see a high side where the teeth arent touching the flat surface, but they do touch on the opposite side.
(these cheap-o things are not machined...they're STAMPED out.)
i use a coarse file, and file the sharp edges off the sides of the teeth. then i do just like Bob says, and make sure that my chain tensioner is where it needs to be.
__________________ New, fully assembled motored bikes here: http://happytimecycles.wordpress.com/ 401-952-7064 Quote:
Originally Posted by Dan sn0rk. | Quote:
Originally Posted by Bikeguy Joe You are one sick man spun, I like that quality in a person. |
