  #10 (permalink)
Old 09-06-2008, 05:41 PM
Nomad Nomad is offline
Banned
Default Re: Gear wobble/oscillation
Originally Posted by Fishermanblues View Post
Thanks for all the tips, I will give the cardboard a try. However I'm still worried that the wobbling gear might cause issues, I don't think that it engages evenly with the clutch. I'm having some problems adjusting my clutch; it slips when I try to engage it when starting, but it also rubs when I lock the clutch with the little pin on the handle bar. I have tried cleaning the clutch plate and the "pucks" with brake cleaner and I have tried adjusting the clutch many times, but to make the rubbing go away makes it slip all the time and to make the slipping go away makes it rub all the time. I have reached as close to a compromise between the two as I can, but it still doesn't seem right.
I'd like to know about that large gear "wobbling" too, I noticed today while inspecting the clutch pucks the same wobbling of the large gear, I think that's where all the "ching a ling" sounds come from on my engine.. where did you get your engine and what size is it...?.
