Old 02-24-2008, 07:53 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: 44 to 36 tooth sprocket swap
Making sure the sprocket fits with a little slop and not tight on the hub. Use the dremel if its a little tight on the center hole.
I'm putting the inside fiber washer in place. I cleaned off the hub and spoke area and checked for loose or broken spokes none were so I'm good to go.
This is the outter fiber washer resting in place.
norms-iron-works.tripod.com
