Old 02-24-2008, 07:45 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default 44 to 36 tooth sprocket swap
Wheel off the bike and mounted in the vice so its easier to work on. The 36 tooth new sprocket is laying on the bench, ready to go on after truing up the center hole which was 1/8" off center
I cheat when I can to make it go easier using an air rachet to get the bolts off. Yes the rachet isn't on the bolt I'm taking the pictures and doing the work Rufus is taking the day off again something about union rules and Sunday.
All parts are off I'm holding the fiber washer that goes inside the spokes it is the only one that gets cut. I'm reusing all mounting hardware
norms-iron-works.tripod.com
