Hi All, Back On July 15, 08 I Posted About 2 Cycles Running Backwards !! He Is A Picture Of The Reason I Asked. This Friction Drive Was On Ebay Auction. I Had Mentioned That Billy The Kid Was Thought To Be Left Handed For Years Because The Negative Was Reversed. Here Is The Reverse Running Motor. The Picture Is Not Reversed, Because The Print Is Correct On The Manual. I HAD NOT CAUGHT THAT ON JULY 15.. The Motor Is Mounted On The Wrong Side For A Normal Motor And The Rewind Turns The Motor Counter Clock Wise.
IF IT WAS A FRONT MOUNT, WOULD STILL BE RUNNING THE WRONG . IT IS MOUNTED TO COMPENSATE FOR COUNTERCLOCK WISE.
WHY DID THEY DO THAT !!!
AS YOU CAN SEE, IT WAS A QUAILTY BUILT MACHINE, CAST HOUSING ETC. LATER, RON
