Re: 44 to 36 tooth sprocket swap 1. I have the dial indicator mounted on the iron strap and the dials stylis on the sprocket checking for side to side wobble once the up and down wobble is gone which I used the wire and eyeball method to true. I should have taken a picture of the strap from the side so you could see it better as to how it was done. The dial is on 0.000 here
2. The max side to side wobble is kept at 0.015 in this picture. Most of the wobble is adjusted out by tightening the high spot bolts
3. The difference in 44 and 36 tooth sprockets. Rufus likes to play with the drill incase you are wondering why the sprocket has so many holes
