Re: Spring Return Chain Tensioner Not haveing started one of those Chinese in frame projects yet I've been following these feedback post on the issues builders are having them. The thought entered my mind for a spring tensioner similar to the rear derailer tensioner (although I doubt one would be available for a size #41 chain)
But in principle....at least it would take up the slack and be flexible.
It seems these chain tensioners are really the #1 issue, followed by the rear sprocket mounting.
I'm sure that in China were they are cranking out this #41 chain that they could easily tool up to make 1/2 links and in time a better tensioner. Usually when there is a crying need for something better someone rises up with "aftermarket" solutions like we're seeing here with 99's solution.
I'd like to see 99 take his photos and put up a post on the "Take a tip & Leave a tip" topic. If he wanted I'd be willing to sketch a black and white projection drawing of how to do it for those wanting to try it.
.......and Egor, thanks bunches for explaining that chain geometry. Recently I was reading about a "lock up" condition where the chain kinking up in the counter shaft gear housing could lead to that...........which once again is a chain tension issue. I've wondered when I look at alot of those old turn of the centruy British bikes that had "chain guides" (I think I saw one set up on an old Excelcior bike) before rollers became popular that just setting up a guide may be the way to go. Yeah, it would be cheap & dirty.....and likely loud....but perhaps dependable. |
