Titan R3 On The Way !!! The Factory has informed me that the Titan R3 carriers are done and being shipped as we speak. I hope for them to arrive in the next few weeks. There are several parts coming from and made in different factories, and then sent to me. I should have them all together and here in the next 2 weeks or so . I expect the pricing to be Excellent and the Quality to be first rate and top Shelf !! The Engineering is superb and proven. This is exciting. It has been a long wait. But now that the factory is tooled up which was a major expense, we can now expect the Titans to be well supplied and I can keep them coming. The Titan will be around half the cost of other Engine carrier setups and better too. The engines are Industrial Commercial and very light at only 12 lbs. Once the new R3 gets here , I will weigh the whole setup. It will be several pounds lighter than the R2 . The R2 was Stainless and heavy. The R3 is Hard Steel and Chromed. So it will be lighter by several pounds. The T brackets are also Hard Steel and Chromed. So.. Stay tuned. I see where someone is asking to rate the Titan to the GEBE. That may happen. Since the GEBE is around 650-800 dollars and the titan Currently around 400 dollars, That would mean that there has to be some rich guy or gal with 1000 dollars or more in order to do the test. As time goes by, we will find those with Titans and with larger miles on them. right now, I have over 2000 miles and the engine is just now getting broken in. I have seen Large saying he has over 3000 miles , so he has surpassed me. But..I am gaining. Also, I am testing a new version of self oiling Jack shaft bearing from the factory. This bearing is designed to take more abuse. IE for those that over tighten drive chains. The Current Bearing has a rubber bushing that can be cooked on over tight drive chain. I know.. We should not over tighten our chains.. But.. A bearing that can take the extra abuse !! I will take it !!! Sorry to be so long on wind.. But..This is exciting for sure !!! Enjoy the ride.. !!!!
