Thread: power band
Old 09-03-2008, 02:39 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: power band
Originally Posted by rickdiculous View Post
am i running my 80cc engine in its power band? it runs good out of the blocks but then starts to "four stroke". if i have a really long stretch to run to get the revs up it seems to power through it, but it really has to get rippin. i'm running a 36 tooth rear sprocket. should i put on the 44? is there a 40t?
You know when you are in the power band, because you feeling the engine torque accelerating faster than the current speed. Power band in motion = butt feel.
I hear this "four stroke" thing all the time - I actually think it has more to do with exhaust than the carb. If you don't have an expansion chamber, then you won't really put the engine power to the ground. Nor will you be able to shift the power band. I think the stock carb actually works OK, and going richer with the needle won't change the top end. I also have news, the engine needs to be a tad leaner at WFO, and you can get there with a smaller jet. Stock is .70mm, I run a .65mm, Ghost0 runs a .60mm.
