Re: Took flywheel off....now wont start Did you check the flywheel sheer key? I'm not sure about a ryobi but on most engines there is a key that aligns the flywheel and crank to make fire at the proper time. A sheered key would give you spark but not crank as the spark is not in time with the piston. I hope this helps. Good luck. |
