Originally Posted by NickDK I just bought a 80 cc 2-stroke and on the instructions it says to cut BOTH rubber/fiber washers and to put BOTH on the inside of the wheel, over the hub. This way the sprocket is tight against the spokes (metal to metal). Is this right? I see you put one of those fiber washers between the spokes and the sprocket...The way I have it with both washers over the hub on the inside is working great -- over 30 miles so far and the chain has never slipped off and the sprocket is very true. |
When reading install instructions I have seen both, cut and do not cut 2nd rubber washers. I decided the do not cut sounded correct. What I have not been able to understand is the wording "Tighten Bolts", how tight is that? 12 ft lbs - 30 ft lbs or ???? - think I am getting anal in my old age.
