Originally Posted by odds10to1 Thank You BlueCollarBike,
The only place I knew of until I stumbled upon 'MotorBicycling.com' was where I bought the motor. They get $7.00 per plug plus $2.00 s/h. They get $21.00 per CDI, plus $5.00 s/h. If you buy both at the same time, you pay both s/h charges also. Their CDI's will only use a plug that has no cap. I was never able to find one that had no cap that was 14mm thread and 11mm reach. Thanks to 'Motorbicycling.com' My problems are being solved at a fraction of what it would have costed me. Thank You again. |
well for future reference You should look at ngk-b6hs or champion L7J for a spark plug.
And you are able to unscrew the wire from your CDI and rundown to a Auto parts store for a replacement wire.
You can cut the wire you purchase and screw it into the CDI.
hope this helps.
cheers
Bob
