Thread: whizzer clutch
  #12 (permalink)
Old 08-29-2008, 07:31 PM
Quenton Guenther's Avatar
Quenton Guenther Quenton Guenther is offline
Dealer
Default Re: whizzer clutch
The history of the Whizzer clutch
I will start this article by quoting the original description of part number 2086 as printed in the 1952 Dealer’s Catalog.
“Purpose
The use of the trunnion bushing will provide easier operation of the entire clutch system. It will also serve as a replacement for all model “H” and “J” motors now in use. Those units, which show considerable wear in the trunnion hole, can readily be overhauled by the installation of this bushing. The use of this bushing in units of this type will prevent mis-alignment of the clutch pulley, reduce service complaints on the rear wheel belts, and provide better service for the customer.”
I guess as early as 1952 someone realized it was important for the pulleys to be in alignment to make the clutch work correctly. It only takes a brief look at the clutch setup on the new edition Whizzers to discover something was lost in the translation. Instead of a nice fitting trunnion pin [#2405] inserted into a special “oilite” bushing [#2086] and pressed into the clutch arm [#2406], we have an off the shelf 12 MM [actually 11.8 MM shank] bolt loosely inserted into two 12 MM I.D. bushings then into a hole in the clutch arm and then held together with a nut. The end result is a loose fitting clutch arm that moves from side to side, and makes it impossible to work as well as possible.
All my new edition Whizzers have modified clutch arms, and I will gladly share with everyone how easy it is to make the changes. On my manual clutch Whizzers the modification has stopped the screeching noises, completely releases at the stop sign, takes off smoothly, and doesn’t slip under stress. On my automatic clutch Whizzers the clutch engages smoothly, bearings last forever, and grip completely [I can pull wheelies on a couple of my Whizzers].
And the fix is……… remove the excessive play where the arm bolts to the motor. The final objective is to remove all side play, so that the pulleys are in alignment. We are dealing with several problems at this junction; first the bolt shank is only 11.8 MM and is too small for the hole in the arm and the bushings at the rear of the motor. Replace the bolt with a piece of ½” drill rod machined to fit the arm and the bushings in the motor, but of course they are also different sizes. The drill rod should be cut down to .475” where it would fit the arm, and .471” to fit the bushings in the rear of the motor. I always drill and tap both ends of the drill rod, one to hold the pin in the motor and the other to make sure the pin and arm never separate.
If anyone wants pictures email me at quincy163@yahoo.com
Have fun,
Quenton
