Old 08-23-2008, 01:28 PM
brucemg51 brucemg51 is offline
Default Re: how to advice needed - friction drive
Originally Posted by deacon View Post
I cant help you I took my clutch off my chainsaw. I attached my drive directly to the drive shaft of the engine. I use a gravity clutch which is no more than raising and lowering the engine.
I agree about the china bike by the way it's why I got interested in the diy friction drives.
How about welding a sleeve over the drum sander's shaft then welding the sleeve to the clutch drive gear.
So you're saying an alternative would be to remove the centrifugal clutch and attach the roller directly to the engine's drive shaft? Then, by using a lever and cable you could lower the engine onto the tire after you got pedaling along. I think I've seen that done somewhere. Question: wouldn't that leave just the weight of engine pressing down to make contact with the tire and would that be enough to prevent slippage? What I've seen is using a quick disconnect and slotted supports to raise or lower the engine. That way you can force the engine down onto the tire with some pressure, then lock it in place.
