Old 08-22-2008, 04:38 AM
reason reason is offline
Default Re: new builder in milwaukee has tech ???
thanks for the info. I did add a small amount of U.S army issue nasty black grease. I did go very light applying it with a tooth brush. I was worried about fouling the clutch. Sounds like a lighter oil type product may do better. Have you ever heard of any one useing a wax style lube like " White lightning " with any luck? Would you know if it is wise to clean the clutch and gears with brake cleaner before I lube again? I just blew it out with the air hose to start with. It seemed to be very clean. None of the metal shave I have heard about in other posts. thanks again
Reason
