Thread: kill switch
Old 08-17-2008, 12:13 AM
pedalpower's Avatar
pedalpower pedalpower is offline
Motorized Bicycle Builder
Default Re: kill switch
Originally Posted by Ilikeabikea View Post
I'd say if a car bumped you and knocked you down and your leg was laying across a moving chain you'd want to kill a screaming engine really fast. I mostly like the kill switch so when I meet a city cop I can push the button, kill the engine and start pedaling................................
if I get run over or off, a sippy cup of a motor racing on it's side is gonna be the least of my worries, pull the clutch, lift, kill motor-wipe dirt from wounds. that's what a chain guard is for-very functional-ever get your fingers caught in a track bike chain?
so, do you mount the kill switch on the left so you can throttle right before you press the button for normal shut off? Actually, I'll probably be putting on a switch-like a firing switch STDP to interupt the blue wire. but unless you're installing some sort of passive (seadoo, snow machine) switch-it shouldn't be considered an emergency kill switch.
El Metodo: La Improvisacion
El Objectivo: Explorar un continente que solo conocen por los libros
El Equipo: La Poderosa
El Che
Let the Solution BE the Revolution
