Thread: Carb problem?
  #10 (permalink)
Old 08-16-2008, 01:17 AM
luke duke luke duke is offline
Motorized Bicycle Builder
Default Re: Carb problem?
I found that the the bowl on the carb was a little slow to fill up when at full speed so drilled the out the hole on fuel inlet very slightly bigger and no longer have the problem. This is an easier solution than adjusting float just be careful like everything to do it in small steps!!!. I am interested in the needle adjustment does moving the washer to the needle point make it leaner on take off or richer? ect
