Re: Just bought 4 stroke Chinese frame mount kit Sorry, I thought you had a 2-stroke too, we'll still try to help where we can. I am courious about this engine also.
The mount for the wheel should be the same as the 2-stroke type, one thing I noticed this in your original post:
. Next, I find the sprocket kit only has 2 half moon clips when there should be 3. And one of the round rubber spacers had 2 big chunks gone out of it.
There are two diffrent types of plates for mounting the sprocket, one set is a 2-piece that is two half circles, and the other is a 3-piece in thirds. I have recieved kits with either of these types or both. When I can I use both layers pf plates layered so that there are no seams to the rubber and everything tightens down more evenly. For the rubber spacers, do you have the solid black rubber or are they cut out of old tires? The solid rubber is junk and crumbles over a short period of time, the tire ones are much more durable and I have never had a problem with them...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
