Thread: Scottys bikes
  #17 (permalink)
Old 08-03-2008, 02:31 AM
DasKapitan's Avatar
DasKapitan DasKapitan is offline
Motorized Bicycle Builder
Default Re: Scottys bikes
Scotty.
Thanks for the info.
My goal is to try to place a four stroke in-frame on a worksman cruiser with a NuVinci rear hub.
I'm now looking at using a Robin EH035. Subaru Robin - Features and Benefits Its lubricating system is such that the engine doesn't need to be upright. Its also built better, cast iron sleeve and so forth. It has the same diaphragm type carburetor as the Honda. Do you think a gravity feed fuel tank would work above these type of engines?
There must be an industry standard for couplings/gears that attach to these class of engines. Can't seem to locate it though. I hadn't even considered pocket bikes until your thread. Again thanks. After searching I found a couple of providers of reduction boxes similar to yours. The covers look different. X7 pocket bike transmission, FS529 gear box, cvt, parts for chinese pocket bikes & Pocket Bike Parts, Gas Scooter, Mini Dirt Bike and Mini Chopper Parts for sale. There's no information on them regarding their actual reduction ratio. If I assume your gear is the same, enclosed chain type, as the above one for an X-7 pocket bike, what was your reduction ratio for planning purposes?
One other question if I may. Are you free wheeling on your jack shaft and just used two right side crank arms on a three piece to gain a sprocket on the left side?
G-Day DasKapitan
