  #67 (permalink)
Old 07-31-2008, 03:29 AM
datz510's Avatar
datz510 datz510 is offline
Default Re: Rotten Orange build - Gary Fisher Aquila shifter buildup!
Also, I've been working on solving some issues related to installing the freewheel crankset on my 73mm bottom bracket. The supplied spindle would not work, so I came up with a workaround which involved removing the chain guide off the rear of the freewheel assembly and installing the widest bottom bracket bearing/spindle set I could find to allow the the freewheel assembly to clear my frame. here is the bottom bracket set that I found that should give me enough clearance for the freewheel crank:
The bottom bracket I ordered was a TH Industries Aluminum Cartridge Bottom Bracket, 73mm Shell x 127.5mm Taper Spindle
Bike Tools Etc. - 1000's of bicycle tools and parts for the home mechanic!
Since this 127.5mm spindle is narrower than the kit supplied spindle, it also may require removal of the chain guide off the back of the chainring assembly. So, i had to have some means of keeping the chain on the chainring when I'm in low gear on the rear cassette. I found this N Gear Jump Start Chain Deflector on JensonUSA as well for $10, so threw that into the order. its an all metal unit and looks to be fully adjustable for the chain line.
https://www.jensonusa.com/store/prod...Deflector.aspx
So, thats where I'm at as of today.. Now, its just another waiting game... waiting for more parts to arrive. In the meantime, I'll see if I can get the gas tank welded up and painted. I'll get photos up as soon as it is done.
