  #13 (permalink)
Old 02-13-2008, 01:00 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Default Re: Front Fender Problem
Originally Posted by nogoodnic View Post
I use hardware store L brackets on all of my bikes with fenders. All you have to do is drill out the original rivets, lose the cheap peice of tin the comes from the factory, replace with the L bracket, the holes should line up with the rivet holes and I bolt it together with 1/4" machine screws, lock washers and Loc-tite on the threads. I also cut one hole off of the side that bolts up to the bike. I haven't had any problems with any of the fenders that I've done this way...Kelly
Thanks for the awesome tip Nic, If I wasn't so gun shy at the moment, I definitely would be putting L brackets on my fenders. As for now, I plan on replacing both tires with the best tires money can buy along with removing my fenders. My little embrace with the pavement was enough to make a corrective plan to reduce my percentage of kissing the asphalt again.
