Old 07-27-2008, 11:00 PM
cruiser66's Avatar
cruiser66 cruiser66 is offline
Motorized Bicycle Builder
Default Re: Anyone design a wet clutch for the 70cc 2 stroke?
This setup keeps the original style manual dry clutch and adds a wet style centrifugal clutch. I believe you would have to add a pull starter because the pedal start would not work. You would probably also have to add a wide crankset to clear the wider engine addons. With a 2 stroke, you loose most of the advantages of having a centrifugal clutch because you have to declutch the engine to let it idle whenever you are coasting or decelerating down long hills. Otherwise, the engine does not receive proper lubrication. However, you can start the engine up and let it warm up without actually having to ride the bike to start it. 4 strokes are ideal for the centrifugal or moped style clutch because they do not experience lubrication problems when decelerating.
eBay 香港 : YX 2 Stroke Bike Bicycle Engine Centrifugal Clutch Kit (物品 300227701187 結束時間 2008-08-23 02小時31分02秒)
66
